Roboumod [Reprog] /!\ TURBO ONLY
Message par tetrao » ven. 26 oct. 2012, 22:06
EDIT : après accord de Robou, voici l'échange questions / réponses que nous avons eu ce soir concernant le Roboumod (traduction possible si vous quelqu'un a des difficultés) :
"I have some questions about your personal e-prom for the Volvo 480 :
- does it only concern the EZ 210 K module (ignition and turbo control) ?
Indeed it does. The Jetronics will know through the communication channel.
- what's the turbo maximum pressure after the modification ?
Within its specification: Approximately 0.95 bar. Build-in safety precautions are maintained from this level, knocking included. No part will be overstressed but for the dumpvalve.
- is it only applicable for the latests versions, or also for phase I ?
Any B18FT engine will profit from the modification.
- what are the approximate values of torque and power one can reach with your e-prom ?
It is not only the mapping in the eprom, some hardware changes are also applied. 250NM and an estimated 180 BHP (160 BHP at wheels).
- what's the cost of the operation ? Does it include the post sending, or not ?
Costs depend on type of ECU: 1 printed circuit board inside will be € 180,--, 2 pcb € 120,--. This is because the former needs my own pcb to be build in. This is shipping excluded.
I need to have the ECU on my workbench. A stock is held for exchange, so a modified one can be send and later the original returned.
Liste des personnes intéressées par l'eprom "Rouboumod", comme vu dans le post de Daniel 480 :
:arrow: tetrao
J'utiliserai cette liste pour faire circuler par MP les infos qui me reviendront de Robou.
ReEDIT : Cf. infos ci-dessus, que Robou m'a autorisé à diffuser. Par contre, il ne souhaitait pas que je diffuse son adresse email. Donc dans un premier temps on dresse une liste (rapidement SVP, genre faudra fixer une deadline), puis je verrai avec lui comment on fait concrètement pour l'envoi et tout ça.
Re: Roboumod
Message par thance » ven. 26 oct. 2012, 22:49
:arrow: tetrao
:arrow: thance
Re: Roboumod
Message par Jerlab » ven. 26 oct. 2012, 23:42
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
Re: Roboumod
Message par Harry » dim. 28 oct. 2012, 08:04
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
Renegade
Re: Roboumod
Message par Renegade » dim. 28 oct. 2012, 11:41
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
:arrow: Renegade
480 ES Two Tone 1992
Re: Roboumod
Message par tetrao » dim. 28 oct. 2012, 19:29
Euuuhhh... par contre les gars il va falloir que ça soit assez rapide, car comme je l'ai écrit plus haut Roubou va bientôt cesser cette activité... :?
Alors à vos claviers ! ;-)
Re: Roboumod
Message par Ben » dim. 28 oct. 2012, 19:46
Rha les boules car c’est complètement exclus pour le moment et pourtant tellement alléchant sur le papier.
ça doit déboiter une 480 avec 160cv :-D
Re: Roboumod
Message par Jerlab » dim. 28 oct. 2012, 20:15
Moi je me pose juste une question sur la pression de turbo.
J'ai souvent lu qu'au delà de 0,7 c'était risqué. Sans autre modif bien entendu.
Là 0,95 ça me parait un poil haut, même si c'est remappé...
Et côté rapidité pas de souci pour moi, je dois immobiliser la voiture le weekend prochain ou celui d'parès pour quelques semaines, donc qu'elle n'ait pas de calculo, ça me dérange pas ;-)
Re: Roboumod
Message par boudav67 » dim. 28 oct. 2012, 20:39
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
:arrow: Renegade
:arrow: boudav67
Re: Roboumod
Message par tetrao » dim. 28 oct. 2012, 23:18
Jerlab a écrit :Moi je me pose juste une question sur la pression de turbo.
Ton escargot souffle déjà à 0,75 bar, mon Jérôme... ;-)
... Comme le B18FT(M) - en boîte manuelle - , d'ailleurs.
Re: Roboumod
Message par Jerlab » dim. 28 oct. 2012, 23:50
Non, c'est 0,55 d'origine (0,45 avant 91) ;-)
Re: Roboumod
Message par tetrao » lun. 29 oct. 2012, 00:05
Bin non, la tienne est groscouplisée, et tape donc le 0,75 comme le B18FT(M) en boîte manuelle. Cf. cette fiche technique. ;-)
Enfin il me semble, hein... :-|
Re: Roboumod
Message par AOD » lun. 29 oct. 2012, 10:30
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
:arrow: Renegade
:arrow: boudav67
:arrow: AOD (père noël, si tu me lis !)
jiair
Re: Roboumod
Message par jiair » lun. 29 oct. 2012, 19:33
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
:arrow: Renegade
:arrow: boudav67
:arrow: AOD (père noël, si tu me lis !)[/quote]
:arrow: Jiair
La consommation n'est pas censé trop évoluer (en bien ou en mal...) ?
Re: Roboumod
Message par Jerlab » lun. 29 oct. 2012, 20:19
tetrao a écrit :Bin non, la tienne est groscouplisée, et tape donc le 0,75 comme le B18FT(M) en boîte manuelle. Cf. cette fiche technique. ;-)
D'après la fiche technique, effectivement oui c'est très clair !!
Mais cette info n'apparaît pas dans Va**s :roll:
Et ça correspond bien à ce que j'ai ressenti après être passé en gros couple.
A l'époque j'avais mon robinet, réglé fin de zone orange en version "standard", le passage en gros couple a fait que ça allait alors en milieu de rouge.
Du coup j'ai viré le robinet :roll:
Re: Roboumod [Reprog] /!\ TURBO ONLY
Message par harchin » lun. 29 oct. 2012, 21:16
:arrow: tetrao
:arrow: thance
:arrow: Jerlab
:arrow: Harry
:arrow: Renegade
:arrow: boudav67
:arrow: Jiair
:arrow: Harchin ( plus on est de fous plus le prix est moins fort ). :mrgreen:
Re: Roboumod
Message par AOD » mar. 30 oct. 2012, 10:09
Jerlab a écrit : Du coup j'ai viré le robinet :roll:
Moi je l'ai laissé...mais si on fait cette modif, clair qu'il sera viré...Par contre, on avait du régler le miens un poil moins virile parce que mon aiguille de turbo ne pénétre dans le rouge que très légèrement... (et encore, qu'on mode "over boost" soit un peu moins de 2 sec grosso merdo)
J'ai voulu faire une annonce sur le file d'info Facebook de l'assoc histoire d'attirer du chaland ...puis me suis ravisé en me disant que c'était pas bien malin d'annoncer à la terre entière qu'on allait modifier les spec tech... :roll:
Message par tetrao » mar. 30 oct. 2012, 10:31
Bin l'idéal serait de connaître un assureur pour qu'il fasse passer le message à tous ses collègues. Moi j'ai un cousin gendarme, je me charge de le lui dire pour qu'il fasse remonter l'info. :mrgreen:
Aïe aïe aïe Nico, ton enthousiasme te perdra ! :aj ;-)
Message par Harry » mar. 30 oct. 2012, 11:33
Tet' : Image , le peuple aura ta peau Image
Message par tetrao » mar. 30 oct. 2012, 11:36
Message par tetrao » mar. 30 oct. 2012, 15:36
Je viens d'avoir des nouvelles de Roland.
Une "mauvaise" nouvelle : pas de prix de groupe. Il argue du fait qu'il a fait cette modif pour lui à l'origine, qu'il a tâtonné pendant trois-quatre ans avant d'arriver à ce résultat, qu'un jour quelqu'un lui a demandé si il pouvait bénéficier de la même modif et qu'ensuite ça a fait traînée de poudre, et surtout que chaque modif lui demande des composants et... du temps (quatre heures par boîtier, et ça qu'il en ait un ou 2000 à faire c'est pareil pour lui). Donc : niet. Ce que je comprends tout à fait, personnellement, surtout que le tarif qu'il pratique est plus que raisonnable comparé à un Fochésato (compter 800-900 boules, sachant qu'ils ne peuvent rien faire sur une phase 2), Rica (400 à 500 boules de mémoire, et idem que Foché pour l'impossibilité de s'occuper des phases 2) et autres.
Sinon concernant la façon de fonctionner, je lui ai demandé si je pouvais vous passer son adresse mail par MP, mais il préfère attendre un peu... En fait il m'a envoyé un boîtier modifié ce matin, et il préfère attendre que je fasse le test moi-même et que je vous livre mes impressions pour que vous passiez ensuite commande en toute transparence pour ce qui concerne son produit. Je vous tiendrai donc au jus dès que je le recevrai, et surtout dès que j'aurai eu l'occasion de l'essayer dans de bonnes conditions (sur circuit, bien entendu...).
La suite bientôt, donc ! ;-)
Re: Roboumod
Message par tetrao » mar. 30 oct. 2012, 17:08
Bon je floode, mais pour la bonne cause...
J'ai regardé sur le forum Europe, et je vous confirme qu'il va falloir virer vos robinets et autres artifices, sinon il va y avoir de la fondue de piston... car ce mode a été mis au point pour des moteurs standard. Pensez-y ! ;-)
Sinon ce mode est apparemment très similaire au Richmod de Rpruen (production stoppée) - d'ailleurs ils ont bossé en parallèle et ont pas mal échangé sur leurs reprogs respectives - , sauf qu'il serait plus doux que ce Richmod, plus souple, moins violent. Mais équivalent en termes de valeurs de couple et de puissance, ainsi qu'en performances. Ce qui expliquerait pourquoi Daniel a si peu hésité à se séparer de son Richmod.
Message par Jerlab » mar. 30 oct. 2012, 21:24
Rhhaaa saligaud, tu va y gouter avant nous.
Moi je suis assez chaud mais un poil hésitant quand même...j'aimerais bien garder mes boitiers d'origine à côté quand même, au cas où :roll:
Il en a pas en stock par hasard ? Bien sur je lui paye ;-)
Message par tetrao » mer. 31 oct. 2012, 02:21
Il a un stock de boîtiers modifiés, mais il les utilise pour prêter à ses clients le temps qu'il modifie leurs boîtiers persos, histoire que leurs caisses ne soient pas immobilisées. Il n'est donc pas vendeur en ce moment.
Il veut arrêter prochainement (mais quand ?), et alors seulement il vendra son stock. Mais il y aura beaucoup de candidats, partout en Europe...
Quand vous entrerez en contact direct avec lui, vous pourrez toujours lui demander si il a éventuellement moyen de coller un switch permettant de repasser en mode normal avec un peu de fil qui dépasse pour coller ça quelque part sur la console, genre à la place du bouton de centralisation. Mais déjà ça risque de coûter plus cher, et en plus il ne pourra peut-être pas le faire pour tout le monde si on commence à être plus nombreux. A voir au coup par coup je pense. Je lui poserai tout de même la question pour le switch. ;-)
Message par remy480julien » mer. 31 oct. 2012, 09:56
Au fait, quand vous aurez bien niqué vos moulins, mais bien cassés hein, faites moi signe pour le restant de la caisse, certaines m intéressent... :ab :ab
