Discotheque on the dashboard
bigdickbuster
Message par bigdickbuster » mar. 04 janv. 2011, 17:21
Bonjour après une longue période de temps!
Au début, je suis désolé que je vais écrire uniquement en anglais, mais j'ai peur que le traducteur en ligne fera désordre
:roll:
Hello after long period of time!
At first, I'm sorry that i will be write only in english, but i'm afraid that online translator will make mess :roll:
As the title says. We (me and my three friends) have similar problem in our 480.
Two people had changed alternator. Two didn't ;) Alternator is brand new. After this operation dashboard looks like on the photo:
(this is photo from one car-only in this car display shows STOP, so this is not important)
Screenwasher, battery and brakes bulb constantly lighting.
When I disconnected from the alternator wire which is responsive for the start of the charging, discotheque goes off.
What should we check?
Kind regards/Meilleurs voeux du froid Polonais, Adrian
1986 480ES, model year '87, 217 Red
1990 480TURBO, model year '90, 231 Red
Re: Discotheque on the dashboard
Message par thance » mar. 04 janv. 2011, 17:32
On the alternator, you have 3 wires... thoses are all connected? (little red one must be correctly connected)
See you
bigdickbuster
Message par bigdickbuster » mar. 04 janv. 2011, 17:46
All wires are connected. Few days ago I noticed that red wire was broken. I fixed it and we know the result ;-) This red wire is for the start of charging and for the "battery" light on the dashboard. When you disconnect it, alternator start charging after exceeding 2500rpm and "battery" lamp does not work. :ag
